Proximity sensor learns and adjusts
IQ Prox inductive proximity sensor has self-adjusting background suppression that learns new environments and adjusts itself regardless of the metal background. It eliminates shielded and unshielded sensors, as well as sensors with extended ranges.
IQ Prox inductive proximity sensor has self-adjusting background suppression that learns new environments and adjusts itself regardless of the metal background. It eliminates shielded and unshielded sensors, as well as sensors with extended ranges. Robust design and ability to be embedded in metal in a recessed mode means better mechanical survival in the industrial environment. Square D Co.
