Product Intros – 2001-12-01
By Staff December 1, 2001
Mobile computer thrives in rugged environments
Hammerhead HH3 is a ruggedized mobile computer powered by a 400-MHz Pentium that combines simplicity of use, high performance, wireless networking, and durability into a compact, lightweight, easy-to-carry package. It offers 256-MB SDRAM, a 10 or 20-GB removable hard drive, and 10.4-in. HI-VIS enhanced color display with pen or touch input.
WalkAbout Computers, Inc.
walkabout-comp.com
Write 371 on PE card
Manage inventory without wires
TankScan W Series wireless measuring system is comprised of wireless measurement monitors, indicators, communication controllers, and a full-featured, PC-based host software package. Among the features included in this bidirectional, battery-powered monitoring system are user adjustable measurement intervals, no calibration after initial setup, and host data exchange via modem or serial link.
Barton Instrument Systems, LLC
barton-instruments.com
Write 372 on PE card
Supply startup time is fast
The wipos Series of switchmode power supplies are designed for up to 90% efficiency and ultra-fast startup time (less than 1 sec). The DIN rail-mountable devices are available in horizontal and vertical configurations in single or three-phase versions from 2 to 4 A. Standard features include thermostated power limitation control and power factor correction.
Wieland Electric, Inc.
wielandinc.com
Write 373 on PE card
Flowmeter supplies four-wire performance
Promag 23 electromagnetic flow meter offers four-wire performance with two-wire economy. The 4-20 mA, loop-powered magmeter generates cost savings through reduced installation costs, simplified hazardous area protection, and lower energy costs. Optimized sensors include those with new PFA molded liners that are suitable for temperatures up to 355 F.
Endress+Hauser, Inc.
www.us.endress.com
Write 374 on PE card
Calibrator has high accuracy
The 525A Temperature/Pressure Calibrator offers high accuracy in an economical benchtop package that includes an easy interface to automated calibration software. It can be used to calibrate process calibration instruments, as well as a wide variety of other pressure instruments, such as modules. The unit sources volts, amperes, and ohms for true multifunction adaptability.
Fluke Corp.
fluke.com
Write 375 on PE card
Meter compensates for electrode offset, slope
PHH-860 pH/mV/Temperature meter is excellent for use in sanitation and wastewater treatment plants. These microprocessor-based, digital meters are able to recognize and compensate for electrode offset and slope. They feature RS232 communication and can hold, relative, and average functions. Features include slope control, 4-digit display which shows pH/F, mV/F, Max/Min, REC, low battery, and calibration up to 3 pH (4.01, 7.01, 10.01).
Omega Engineering, Inc.
omega.com/green/pdf/phh860.pdf
Write 376 on PE card
Level gauge provides high resolution
Level Plus M Series magnetic level gauge transmitter can be mounted to most magnetic (sight glass) gauges. It is approved for both explosion-proof and intrinsically safe usage with Cenelec/PTB approvals available. The unit has an optional LCD display to read level, mA, or percent of full scale. The transmitter offers two-wire, 4-20 mA analog output, and multidrop HART communications.
MTS Systems Corp.
levelplus.com
Write 377 on PE card
Belt provides drainage
Series 1800 Mesh Top Belt has 32% open area. It combines generous drainage and liquid flow-through while safeguarding against product loss and damage during production. Perforations are slotted and tapered, providing optimum water flow for drainage and product dewatering.
Intralox, Inc.
intralox.com
Write 378 on PE card
Paint protects against harsh environments
The 4800 Series of high-performance polyurethane gloss enamels is formulated to refinish and protect equipment. The enamels provide excellent durability and attractive color and gloss to equipment that must withstand chemical solvents, smoke, high temperature, physical abrasion, and repeated steam cleaning. The paint can be applied with brush, roller, air, airless, or HVLP equipment.
Magnet Paints
magnetpaints.com
Write 379 on PE card
Trap drains superheated mains
FS5H QuickTrap is a high-pressure, free-float steam trap designed for drainage of superheated or high-pressure steam mains, equipment, and turbines up to 650 psig. The two-point universal connector trap has three-point seating to ensure a steam-tight seal under no-load conditions.
TLV Corp.
tlv.com
Write 380 on PE card
Hand pump calibrates instruments
TP1 pneumatic, hand-held, portable pumps supply pressure with standard, fine-tuning adjustments and pressure relief valves. These pumps are ideal for use with electronic calibrators, analog gauges, and similar instrumentation. The pump generates 360 psi or vacuum to 25 in. Hg. The unit is designed to endure harsh environments.
TTI, Inc.
ttiglobal.com
Write 381 on PE card
Switches for complex applications
Series 31 instrument and control switches are designed to meet the demands of complex switching applications. With a continuous rating of 15 A at 600 V, they feature a detent action that provides for up to 10 decks (20 poles) and up to 8 positions. Models feature double-wiping, silver-plated contacts.
Electroswitch Corp.
electroswitch.com
Write 382 on PE card
Monitor protects motors
MotorSaver Models 355 and 455 three-phase voltage monitors provide protection from incoming power problems by sensing the power supply to the motor and disconnecting before damage occurs. The monitors sense rapid cycling, single phasing, low voltage, phase reversal, voltage unbalance, high voltage, and phase/frequency shift.
SymCom, Inc.
symcominc.com
Write 383 on PE card
Inverter increases weld performance
Invertec V160S is designed for stick welding with some TIG applications. The unit offers the capabilities of Touch Start TIG or stick in DC. With an easy starting stick feature, users just have to touch the electrode to the workpiece and lift up to start an arc.
The Lincoln Electric Co.
lincolnelectric.com
Write 384 on PE card
Containers transport lubricants
Oil Safe containers provide a safe, easy method of transporting, handling, and dispensing lubricating fluids in a wide variety of applications. These products are durable and made from high-density polyethylene to perform in hostile environments.
Trico Mfg. Corp.
tricomfg.com
Write 385 on PE card
Turbine supplements utility power, generates savings
PowerWorks microturbine offers an opportunity to reduce the consumption of expensive utility-grid power by providing a reliable, onsite source of lower cost electricity. Fueled by natural gas or alternate fuels, the efficient microturbine generates savings by operating economically and continuously at lower cost than utility rates.
IR Energy Systems
irpowerworks.com
Write 386 on PE card
Shaft seals manage vibration
Safematic SB1A and SB2A single and double, heavy-duty cartridge seals can handle punishing vibration, shaft motion, shock, and cavitation without face distortion or cracking, O-ring hang-up, leakage, or failure. A patented technique for fastening the seal faces without drive pins ensures correct face alignment, even at elevated temperatures.
John Crane
johncrane.com
Write 387 on PE card
Related Resources
