Process control, asset management integration
Plant Asset Management uses a combination of software, smart instrumentation and fieldbus communications to continuously monitor critical plant assets, reducing the risk of failures while increasing equipment availability. Designed to integrate into the PCS 7 process control system, the software suite requires minimal engineering and configuration efforts.
Plant Asset Management uses a combination of software, smart instrumentation and fieldbus communications to continuously monitor critical plant assets, reducing the risk of failures while increasing equipment availability. Designed to integrate into the PCS 7 process control system, the software suite requires minimal engineering and configuration efforts. It integrates all plant assets into a single location for both process control and asset management information. The asset management software provides a comprehensive platform that includes all plant assets such as valves, process instrumentation, computers, networking equipment, drives, motors, pumps, process control components such as control processors and I/O modules, process analyzers and non-intelligent assets such as heat exchangers and other process equipment.
Siemens Industry Inc. www.usa.siemens.com
