Pressure transducers – 2006-08-18
By Plant Engineering Staff August 18, 2006
Built using rugged, bonded-foil strain gage (BFSG) technology, the company’s line of pressure transducers is suitable for industrial and military applications. The transducers feature a pressure-overload protection capability for the diaphragm called the Over Travel Stop (OTS), which enables the sensing element to handle a minimum of five-times full scale over-range pressure spikes. This design also affords thermal isolation to high-temperature transients, shock loads and vibration, allowing bonded foil strain gages to be used in extreme military, aerospace, and industrial applications,
the company says.
Measurement Specialties
https://www.meas-spec.com/myMeas/sensors/sensorTransducers.asp
Related Resources
