Pressure switch for tough environments
Sigma-Netics Inc. has added a 2-pin Deutsch connector option to its 784 Series of ruggedized pressure switches. The 2-pin option allows the 784 Series to serve a wider range of applications, including those with limited installation space.
Sigma-Netics Inc. has added a 2-pin Deutsch connector option to its 784 Series of ruggedized pressure switches. The 2-pin option allows the 784 Series to serve a wider range of applications, including those with limited installation space. The 784 pressure switch is compliant with IP67 standards for maximum environmental protection. This model is ideal in tough environments containing oil, fuel, water, dust, vibration or shock. It’s a piston-based design with an 8 to 6,000 psig range. The the customizable pressure switch features a snap-action electrical switch tested to one million cycles, gold contact switches for dry circuit applications, high overpressure capabilities and custom configurations.
Sigma-Netics, Inc.
