Predict to prevent: Motor management systems look into the future
With the ability to predict what will happen to a motor, and by extension an industrial process, motor management systems can become the single most important tool to mitigate industrial manufacturing downtime.
05/07/2009
Even an hour of process downtime in an industrial manufacturing facility can cost hundreds of thousands of dollars. In a fragile economy, that can mean the difference between meeting and exceeding production goals, or falling well short. The question then becomes, what can be done to mitigate unscheduled downtime?
The continuous, reliable operation of electric motors is valuable to most critical manufacturing processes. That's why a motor management system is a very valuable asset to industrial facilities management. These systems reside on the factory floor within control panels or intelligent motor control centers, and facilitate remote control, monitoring and protection of electrical motors and processes.
Four steps to prediction
The ability of a motor management system to predict what could happen to a motor is built around four critical features.
Advanced monitoring capabilities play a key role in a robust motor management system. A system should have the ability to accurately monitor current, voltage and power over a wide range. Armed with this data, a motor management system will be able to predict potential process downtime more accurately, thus allowing that downtime to be scheduled during non-critical time periods.
Data recording capabilities are essential for effective prediction. Faults and similar events throughout the facility's automation system should be recorded, time-stamped and saved in non-volatile memory, all of which can be achieved by a robust motor management system. This information can be used for preventive maintenance tasks and to better predict potential unscheduled downtime for critical processes.
Having an open architecture and the ability to connect to SCADA and power management systems is critical to successful motor management. Why? Connection to SCADA systems will enhance predictive features of each system, while connection to a factory-wide power monitoring system will allow better energy management at the facility level. With energy costs continuing to escalate, that means motor management systems are a "green" alternative, helping to monitor and conserve energy while simultaneously conforming to higher environmental standards.
Finally, motor management systems should offer a comprehensive battery of current, voltage and power protection , along with advanced warning features. Protection features offered by motor management systems will protect equipment investments while advanced warning features will help to predict potential unscheduled process downtime.
Flexible connectivity and control
Increasing the availability of critical processes is the mark of an effective motor management system. To optimize this availability, motor management systems should integrate seamlessly into an industrial facility's automation systems and have the ability to communicate directly to SCADA systems and PLCs. Seamless integration also requires support of the major industrial communication protocols (such as Ethernet, Modbus, CANopen, DeviceNet and PROFIBUS).
Motor management systems also need to be flexible enough to allow integration into an intelligent motor control centers (iMCCs). Critical processes in the mining, oil/gas and water/wastewater applications are using iMCCs to control and manage electrical motors. Integration into an iMCC requires motor management systems to be very compact, able to withstand high operating temperatures, and offer wide full-load current adjustment.
Easy commissioning, use and maintenance
Though a motor management system should be very flexible to minimize process downtime, it will lose its luster if commissioning, use and maintenance are very complex. This is why it is critical for motor management systems to be seamless to commission, easy to use and simple to maintain.
Intuitive PC-based software can simplify the motor management system commissioning stage. These advanced software packages are able to commission the entire solution a facility is implementing. Standard software will afford consistency and speed up commissioning. A PC may not be readily available for set-up and commissioning tasks, which is why motor management systems should also include advanced HMI options for non-PC users. Those HMI options should be intuitive and easy to use to allow operators on the floor to perform quick adjustments to the motor management system.
Flexible connectivity with major industrial communication protocols (such as Ethernet, Modbus, CANopen, DeviceNet and PROFIBUS) can also simplify commissioning activities by centralizing those tasks to a single control station. Advanced communication protocols like Ethernet make the use and maintenance of motor management systems easier than ever. Ethernet communication supports Web services, which could be used on a PC to run diagnostics, or set up a system for monitoring. No special software is needed, since a simple Web browser can do the job.
Fabrice Meunier, Schneider Electric Business Development Specialist, graduated in 2001 with a master's degree in electronics and computer science (Paris, France). He is currently pursuing a master's degree in business administration at North Carolina State University. He can be reached at fabrice.meunier@us.schneider-electric.com.
