POY Finalist: Portable oscilloscopes
Finalist in Maintenance Tools and Equipment in Plant Engineering’s 2011 Product of the Year competition
The ScopeMeter 190 Series II handheld portable oscilloscopes are safety rated for CAT III 1,000 V / CAT IV 600 V environments. The four input channels are fully isolated from each other to perform differential floating measurements, a critical consideration for troubleshooting fixed-installation three-phase power electronic devices like variable speed motor drives.
The ScopeMeter chassis is sealed from the environment with no cooling slots or fans to expose the instrument. The oscilloscopes are tough enough to safely use on the factory floor and in the field.
Fluke Corp.
View all finalists in the Maintenance Tools + Equipment category
