POY Finalist: Interruptible inverter
Finalist in Lighting in Plant Engineering’s 2011 Product of the Year competition
By Edited by Amanda McLeman, Plant Engineering November 1, 2011
The LiteGear inverter is designed to provide a maximum of 250 VA of emergency power to indoor and outdoor lighting fixtures for up to 90 minutes. The LG2 interruptible inverter easily handles larger emergency lighting load requirements in indoor office areas and long outdoor walkways, including LED, incandescent, linear fluorescent, and compact fluorescent lamps.
The heavy-duty steel enclosure features a white powder coat finish and is designed for indoor surface wall-mounting installation. The LG2 may be mounted up to 1,000 ft away from indoor or outdoor connected loads.
Dual-Lite
www.dual-lite.com
View all finalists in the Lighting category
