Powering reliable entertainment
Mission-critical entertainment may seem like a misnomer, until considering that commercial time for some venues exceeds $1 million per minute, meeting or exceeding downtime costs for many major manufacturing sites.
05/31/2013
Saunders Electric generator provides quiet reliability using Mitsubishi Electric controls. Courtesy: Mitsubishi Electric AutomationSaunders Electric, which has been supplying the broadcast industry with reliable power solutions with studio-quiet generators since the early 1990s, knows that in the entertainment business, failure isn’t an option. The company actively refines its products and in 1994 began using a rack-style, modular programmable logic controller (PLC) to synchronize generator and landline power sources. This helped create a power signal that more closely replicated the main grid supply. With a higher quality power signal, Saunders Electric can better support the hypersensitive media equipment used in the film and broadcast industry with zero interruption and no degradation of signal during grid outages.
Show must go on
Power outages or failures at home and work can create frustration but rarely affect show business. Entertainment industry special events demand perfection, requiring reliable power. As the saying goes: “The show must go on.” Broadcast and entertainment industry companies rely on portable, temporary power services to eliminate grid outages and brownouts. Saunders Electric has provided products and services to entertainment events including: the Academy Awards, the Emmys, the Grammys, the American Music Awards, ESPN college basketball, and others.
Control platform, HMI
Mitsubishi Electric GT16 Interface screen has an extended viewing angle, enabling operators to be more mobile while the power system is in use. Courtesy: Mitsubishi Electric AutomationSaunders Electric upgraded to a new control platform and new human-machine interface (HMI) for improved performance and a more intuitive, visual operator experience. The new generator control system added features and performance available in today’s automation controllers. During the selection process, Saunders Electric considered a variety of new automation and control options. However, in an industry where power failure is unacceptable, a track record for outstanding reliability goes a long way in the decision process. After years of using a control system without failure, upgrading to the next generation was a logical choice.
The new controller provides other performance benefits and advantages such as faster processing speeds, advanced analog control, more flexible graphical interface, and a significantly smaller hardware footprint, increasing space in the cabinet for other devices.
Shorter implementation
Saunders Electric benefited from a short implementation time, completing the transition to the new control system in one month. This short implementation period kept costs down, and the company was able to see a return on investment (ROI) more quickly.
Adding to power quality, high-speed, digital-to-analog signal conversion permits faster response times when matching generator speed to the grid power signal. This minimizes the effect of overshoot, providing a cleaner power signal for broadcasting equipment.
Russell Saunders is president and CEO, Saunders Electric. Courtesy: Mitsubishi Electric AutomationOperator effectiveness was also greatly improved. Extended HMI viewing angle enables operators to be more mobile while the power system is in use. Design software helps create more intuitive screens, improving setup and monitoring efficiencies. Continued reliability was essential to the system upgrade.
A hardware and software quality control program provided assurance that the Saunders Electric synchronous power system will keep running, providing highly dependable, temporary power services to the broadcast industry.
Hardware advantages
Hardware includes the CPU, analog module, input module, output module, Modbus master, and HMI. The system provides strong-build quality, high-speed sampling, and intuitive HMI screen designs with greater viewing angle, for higher reliability, improved power quality, and greater operator effectiveness.
Saunders Electric Inc. noted that it has used the same “control systems on our load command systems since 1994 and never had a live show go off the air.”
- Greg Hookings is marketing communications manager, Mitsubishi Electric Automation Inc.; Edited by Mark T. Hoske, content manager, CFE Media, Control Engineering and Plant Engineering, mhoske@cfemedia.com.
ONLINE
www.saunderselectric.com
www.meau.com
See related product article linked below.
