Power: Ultracapacitor module eases system integration
Morrisville, NC—Raycap Inc., a leader in transient voltage surge suppression technology, has developed a 40 mm version of its Strikesorb module that the company says can be easily integrated inside OEM equipment, panelboards, cabinets, and switchgear equipment.
06/28/2007
Morrisville, NCRaycap Inc. , a leader in transient voltage surge suppression technology, has developed a 40 mm version of its Strikesorb module that the company says can be easily integrated inside OEM equipment, panelboards, cabinets, and switchgear equipment. The unit’s fuseless design enables direct installation on busbars on the load side of a circuit breaker, eliminating the need to install additional interconnection wires or circuit breakers or fuses. Housed in a 2.5 in. diameter, 3.72 in. height hermetic aluminum package, the 40mm Strikesorb module meets the stringent requirements of the UL1449 - 2nd edition - safety standard. The modules are designed for use in applications that require protection from lightning and power surges, such as oil, gas and petrochemical equipment; power generation equipment; wind turbines; industrial automation; control and process management electronics; variable speed drives (VSDs); uninterruptible power supplies (UPSs); telecommunication and cable TV equipment; radar equipment; telecommunication street cabinets; medical equipment; and other applications requiring continuous operation because safety is critical.
“The 40 mm Strikesorb module’s small size and fuseless design makes it ideal for integration into equipment that requires protection against damage-causing transient surges,” says Matt Hemphill Raycap’s engineering manager for North America. “Due to the recent sweeping changes in the UL1449 standard, most TVSS and SPD systems are losing their UL certification. Under the provisions of the National Electrical Code (NEC), a TVSS device may not be installed if it is not UL Listed. System integrators, specification engineers, infrastructure contractors and OEMs must be careful that they are using appropriate UL Listed devices.”
The company says that the Strikesorb module is the only UL-recognized surge protection device (SPD) that has been fully tested to the complete testing procedure as defined by the revised UL1449 standard. Equipment that includes the 40 mm Strikesorb module does not need further UL 1449 testing to meet UL Listing requirements, saving integrators and panel manufacturers time and money. In addition, Strikesorb modules have passed 3-cycle testing at available short circuit currents of up to 100,000 A rms. This allows them to be directly installed behind circuit breakers of any rating and ability to interrupt short circuit currents up to 100,000 A rms. The company also claims that the 40 mm Strikesorb module is the industry’s only transient voltage surge suppression (TVSS) module that can withstand repeated surges to provide uninterrupted protection from surge currents of up to 140 kA, and meet the new UL1449 2nd edition requirements without internal fuses or thermal disconnects.
The module has one 40 mm diameter distribution-grade metal oxide varistor (MOV) disc that provides uniform distribution of the surge current over the total MOV protection element area, resulting in a high-energy handling capability combined with ultra-low let-through voltage to the protected equipment. The Strikesorb’s unique monolithic design provides a straight electrical path to its large single disc of distribution-grade varistor material, unlike other TVSS systems that employ arrays of conventional MOV components with 90° angled lead wires to each varistor. The absence of lead wires and internal disconnect mechanisms gives the Strikesorb extremely low contact resistance. The module also exhibits low clamping voltage and can be directly connected on the power bus bars inside the cabinet of the equipment after the main circuit breaker. The company says it can be integrated inside systems or within Raycap’s Rayvoss stand-alone TVSS system in a variety of configurations and operating voltages including single-phase, split-phase, three-phase wye and three-phase delta configurations with voltages that range from 120 V to 600 V respectively.
Edited by C.G. Masi , senior editor, Control Engineering
Machine Control eNewsletter
