Power turn conveyors move small packages
L-Series power turn conveyors allow the smooth handling of small parts around curves. Uniform transfer and alignment of small products are possible due to small end roll diameter and tapered end roll design.
By Staff October 1, 1999
L-Series power turn conveyors allow the smooth handling of small parts around curves. Uniform transfer and alignment of small products are possible due to small end roll diameter and tapered end roll design. Adaptable to a wide range of applications, power turns are available in standard arcs of 15-180 deg and belt widths from 4-48 in.
Portec, Flowmaster Div.
www.portecflo.thomasregister.com
Circle 377
