Power Transmission
05/06/2003
All about hydraulics
Three-day hydraulic training sessions are held from May to August throughout the country. They cover principles, pumps, motors, cylinders, fluids, valves, auxiliary devices, transmission lines/fittings, basic circuits, electro-hydraulics, and troubleshooting. National Technology Transfer, Inc. nttinc.com Write 310 on PE card
Hydraulic tank breather
Des-Case Hygroscopic Breathers remove moisture and particulate from wet, dirty air entering hydraulic tanks, gearboxes, or large tanks. The device employs a desiccant to extract water vapor from the air and a microglass, pleated filter to remove particles down to 1-micron. Sphinx Adsorbents, Inc. sphinxadsorbents.com Write 311 on PE card
In-line gear reducers
A series of gear reducers are compatible with any positive displacement pump or other equipment needing speed reduction. The input and output shaft are in-line for easy alignment and space savings. Ratios vary from 2.6:1 to 35.1:1. Horsepower ranges from 0.5 to 350. Viking Pump, Inc. vikingpump.com Write 312 on PE card
Digital gauge
DGR-1 digital pressure gauge is battery-operated, providing up to 1400 hr of continuous operation and displays pressures up to 15,000 psi. Features include: readings in bar, Mpa, kPa, and mbar at the touch of a button, automatic shut-off, maximum and minimum pressure capture, zero reset, and a 355-deg display rotation. Enerpac enerpac.com Write 313 on PE card
Tough hose bends easily
472TC hose is for high-impulse applications requiring superior flexibility. It features a one-half SAE 100R12 minimum bend radius and exceeds SAE 100R16 specifications, meaning installation is easy and less hose is used. With a 15% to 35% higher working pressure than SAE 100Rs2 hose, the two-wire braid hose has an oil-resistant, synthetic, high Nitrile rubber tube that handles a variety of fluids. Hose Products Div Parker Hannifin Corp. parkerhose.com Write 314 on PE card
Tough shaft seals
ROTAFLON seals are available in MC series, a polymer seal lip with or without an embedded spring, and RB series, a polymer sealing surface bonded to an elastomeric seal lip. Seals can be used at surface speeds up to 5900 fpm and temperatures from -58 F to +500 F. The seal material has good chemical resistance and is suitable for operation with poor lubrication. American High Performance Seals, Inc. ahpseals.com Write 315 on PE card
Fast servo valves
Servocartridge valves feature a poppet and sleeve design.
DSHR valves have flow rates up to 165 gpm at 72.5 psi pressure drop and a 12 msec step response time at 100% stroke. SE 3 valves have a frequency response of 170 Hz at -3dB and a 12 msec step response time at 100% stroke. Industrial Controls Div. , Moog, Inc. moog.com Write 316 on PE card
Bearing catalog
Comprehensive 64-p catalog covers the latest improvements in a full line of self-aligning roller bearings. Engineering section provides information on selection and application. Other topics include: seals, mounting, load-rating tables, interchangeability, installation techniques, and lubrication guidelines. Rexnord Bearing Group rexnord.com Write 317 on PE card
High-cycle clutch/brakes
A 6-p color brochure highlights the 2-to-10X higher cycle rates and 5-to-10X longer operating life of the oil-shear Posidyne X Series clutch/brakes. Listed are specifications and performance charts covering torque ranges of 100 to 1000 in.-lb. Force Control Industries, Inc. forcecontrol.com Write 318 on PE card
Applying the binders
A 6-p color brochure details a complete line of general purpose, mill duty, and heavy-duty brakes as well as the Braketronic Controller. The controller provides variable torque control of thruster-operated shoe or disk brakes, replacing high-maintenance, power-assisted air over hydraulic systems. Mondel Engineering mondelengineering.com Write 319 on PE card
Hot/cold alignment fixture
OL2R fixtures are easy to use and solve a major problem by measuring the true dynamic movement of rotating machinery as it goes from offline (cold) to operating (hot) conditions. This measurement provides the information to intentionally misalign machinery when aligning, ensuring they will grow into an aligned condition when running. VibrAlign vibralign.com Write 320 on PE card
