Power connectors rotate 360 deg
The 518 Series high power, single pole connectors feature a 360-deg, non-specific, locking collar design that allows the connector pairs to be mated and locked in any orientation.
The 518 Series high power, single pole connectors feature a 360-deg, non-specific, locking collar design that allows the connector pairs to be mated and locked in any orientation. Once engaged, a ring provides the connectors with a positive locking force up to 300 lb while allowing free rotation, even with rigid cables. The connector is designed for currents from 50-1000 amps and voltages up to 5 skV.
Duraline
www.jbn-duraline.com
Circle 384
