Portable compressor reduces size and weight
XAS 96JD portable air compressor is compact, lightweight, and features an airend that has high efficiency. A water-cooled diesel engine has a two-stage, cartridge intake filter with replacement indicator. An extraction system reduces oil consumption.
XAS 96JD portable air compressor is compact, lightweight, and features an airend that has high efficiency. A water-cooled diesel engine has a two-stage, cartridge intake filter with replacement indicator. An extraction system reduces oil consumption. The large capacity fuel tank is placed low for good road handling and easy filling. Atlas Copco Compressors, Inc., Portable Air Div.
