Poke-through provides multiple connections
Multiple-service, fire-rated poke-through accommodates both cate- gory 5 and power service. Unit houses four category 5 data or voice jacks and four insulated 15-amp, 125-V receptacles.
Multiple-service, fire-rated poke-through accommodates both cate- gory 5 and power service. Unit houses four category 5 data or voice jacks and four insulated 15-amp, 125-V receptacles. Receptacles mount to the fitting, allowing cover and flange to be installed without removing receptacles. Low-voltage conduit entrances provide convenient cabling protection.
Hubbell, Inc. (Delaware), Wiring Device – Kellems; www.hubbell-wiring.com
TO VOTE, WRITE 46 ON BALLOT
For more information, circle 1 on card
