Plug for Profinet, Ethernet applications
The M12 Cat. 5 plug with D-coding is designed for Profinet and Ethernet IP applications that require a robust and reliable connection.
Offering data transfer rates of up to 100 Mbit/s, the M12 Cat. 5 plug with D-coding is designed for Profinet and Ethernet IP applications that require a robust and reliable connection. The M12 plug is made from Die Cast zinc and features a 360 degree shield around the cable. The field plug accepts cable OD’s from 5.0 mm to 9.7 mm and conductor sizes AWG 26/7 to 22/7 and AWG 24/1 to 22/1. The M12 plug offers mechanical and electrical resistance along with an IP67 rating.
Metz Connect
