PLC for enhanced cybersecurity, integration
Honeywell Process Solutions' (HPS) ControlEdge programmable logic controller (PLC) is designed to reduce integration efforts and project costs as well as enhanced cybersecurity for industrial facilities.
Honeywell (NYSE: HON) Process Solutions’ (HPS) ControlEdge programmable logic controller (PLC) is designed to reduce integration efforts and project costs as well as increased security and availability through enhanced cybersecurity for industrial facilities. The PLC is designed for use in a variety of balance of plant applications such as equipment and device level control. It also offers secure connectivity and leverages a common human-machine interface (HMI) platform to provide faster field device commissioning, and improve device diagnostics. The PLC designed for end users, original equipment manufacturers (OEMs), and engineering, procurement and construction (EPC) companies, particularly those in global refining, oil and gas, power, chemical, water management industries, and infrastructure applications. ControlEdge PLC provides an IIoT-ready open platform that uses OPC Unified Architecture (UA) as a communication protocol and enables users to better leverage data across their assets.
Honeywell Process Solutions (HPS)
– Edited by CFE Media. See more Control Engineering PLC and PAC products.
