Plastic bag filters
All-plastic Polyline bag filters can filter a range of corrosive fluids. An alternative to metal-alloy filters, they can be used in ultrapure filtration applications where metallic and other types of contamination are a concern. The bag filters are manufactured using a unique process that produces a rugged, one-piece seamless body with no welded or glued seams or connections to fail and leak.
02/01/2007
All-plastic Polyline bag filters can filter a range of corrosive fluids. An alternative to metal-alloy filters, they can be used in ultrapure filtration applications where metallic and other types of contamination are a concern. The bag filters are manufactured using a unique process that produces a rugged, one-piece seamless body with no welded or glued seams or connections to fail and leak. The seamless body is designed to ease cleaning. The filters have also been designed so that the two bottom pipe connections are interchangeable as an outlet or drain, facilitating installation into either a loop or in-line piping system, without having to modify the filter. Filter bag change-out is quick and easy, as no tools are needed to remove the filter cover. The bag filters are available in PVC, CPVC, PPL or PVDF constructions, with threaded or flanged piping connections. The filters are rated to 150 psi at 70 degrees F and are available in two sizes, one for standard, single-length number one filter bags and one for standard, double-length number two filter bags.
Eaton Filtration, LLC
www.filtration.eaton.com
