PLANT ENGINEERING COST INDEX* – 1998-12-01
Change, % Current Month Year Facilities group index ago ago Clay construction products 145.3 0 0.8 Electric devices 148.7 0.4 1.8 Foundry and forge products 135 0 0.7 Glass 106.8 -0.2 -1.5 Gypsum products 180.1 0.7 3.
Change, %
Current Month Year
Gypsum products 180.1 0.7 3.7
Heating equipment 153.4 0.1 0.3
Lumber 171.1 -1.4 -8.5
Plywood 157.3 -8.3 0.8
Millwork 171.7 0.3 0.4
Paint 155.6 0.1 2.1
Copper-based alloy rod 163.2 0 -19.2
Pipe, steel 107.7 -0.9 -0.8
Plumbing fixtures 174.4 -0.1 -0.3
Sash, metal frame trim 161.8 0 0.1
Sheet metal products 142.8 0.2 1.3
Tanks, metal 125 0.1 1
Wire, steel 107.7 -0.3 -0.8
Wiring devices 154.5 -0.1 0.0
Valves 158.3 0.1 1.3
Material component 149.8 -0.1 -1.1
Labor component 140.5 0 3
Facilities index 143.8 -0.1 1.1
Change, %
Current Month Year
Equipment group index ago ago
Abrasives 143.5 0.1 0.1
Bearings 165.7 0.1 1.5
Belting 148.3 0 1.4
Bolts, nuts, and screws 128.8 0.1 1
Hand tools, mechanical 165.7 0.4 1.3
Lubricants 132.1 4.8 7.2
Metals (steel products) 111.7 -1.4 -4.2
Metals (nonferrous) 120.0 -0.7 -11.1
Metal products (miscellaneous) 126.0 0 -0.2
Motors 146.2 0.2 1.1
Power transmission equipment 158 0.3 1.9
Precision tools 152.4 -0.1 1.0
Pumps 159.2 0.1 1.7
Tools, cutting 140.2 0.1 1.9
Wire and cable (nonferrous) 140.1 -0.3 -4.4
Material component 142.9 0.3 0.2
Labor component 160 -0.1 3.1
Equipment index 153.4 0.2 1.8
Plant Engineering Cost Index 150.4 0.1 1.5
* Base Year: 1982=100
