Planetary mixers
Double planetary mixers designed for high-precision formulations.
Double Planetary Mixers designed for high-precision formulations have two rectangular planetary blades that rotate on their own axes, while they orbit the mix vessel on a common axis. This mixing action is ideal for moving viscous fluids or wet granulations. The stainless steel heavy-duty sealed gearbox housing includes a sloped cover to prevent contamination and pooling of condensed liquids. Solvent vapors and airborne particles are likewise prevented from entering the purged gearbox. These mixers also feature a gable-roofed bonnet to avoid dust or water collection. All ports and connections are tri-clamp design. Atomizing spray nozzles are installed on dedicated ports for controlled and spill-free addition of liquid raw materials into the batch.
Charles Ross and Son Company
