Participate in maintenance benchmarking survey
By Plant Engineering Staff May 3, 2006
Klaus Blache from General Motors Corporation will conduct a maintenance benchmarking survey modeled after a similar study done several years ago while he was chairman of the Society of Maintenance and Reliability Professionals.
Download survey (PDF)
The purpose of the study is to compile current maintenance benchmarking information and viewpoints by repeating parts of two past studies done (1991 & 1997). Blache conducted the earlier analysis, and these results will be compared to looks at trends.
Survey participants also will be given the resulting report. As before, the survey uses ratios and percents for anonymity and no company names are ever mentioned. A summary of the findings will be published in PLANT ENGINEERING.
To participate, download a PDF version of the survey, which can be found at www.plantengineering.com under the‘In The News’ section. It should be filled out, scanned and emailed to kmb-mail@hotmail.com .
