Outdoor IP camera dome
The IKS-WR7413 IP is designed to be a first line of defense for schools and businesses by monitoring everything that is happening outdoors even in complete darkness.
The IKS-WR7413 IP is designed to be a first line of defense for schools and businesses by monitoring everything that is happening outdoors even in complete darkness. With its three-megapixel video resolution and LED IR illuminators, the camera dome provides high video quality with four simultaneous video streams. The IKS-WR7413 can be adjusted to cover a wide field-of-view or narrow it’s focus to a smaller area for additional detail, and it is outfitted with four adaptive infrared LEDs to capture images up to 25-ft away in the complete absence of light. The dome’s True Day/Night Imaging technology converts blurry color images into crisp black and white video when monitoring in darkness. Additional capabilities include: recording in two different codecs, integration with ONVIF compliant recorders, and memory storage up to 64GB.
Toshiba
