OSS oil-water seperator
Atlas Copco adds OSS to range of oil-water sperators for condensate treatment in low-flow compressors.
By Atlas Copco August 29, 2016
Atlas Copco adds OSS to range of oil-water sperators for condensate treatment in low-flow compressors. The OSS performs condensate treatment for oil-injected piston and screw compressors below 15 kW. The OSS treats condensate in multiple phases of treatment including a depressurization chamber and pre- and post-filtration. The OSS utilizes an advanced absorption media to reach purity levels below 15 ppm at flows up to 60 cfm. A lightweight design allows the OSS to be wall mounted for easy access and replacement. A disposal cap and plug make a clean replacement routine possible, and the entire unit is 100 percent recyclable.
Atlas Copco
www.atlascopco.com
www.atlascopco.us
