Optical bypass relay
The OBR40 optical bypass relay by Belden is designed for harsh environments and both ring and bus topologies as well as an IP30 protection rating.
07/08/2013
The OBR40 optical bypass relay by Belden is designed for harsh environments and both ring and bus topologies as well as an IP30 protection rating. Courtesy: BeldenBelden's OBR40 optical bypass relay is designed for harsh environments. The relays increase the availability of fiber-optic Ethernet networks by ensuring that they remain operational despite power failures at one or more switches. These relays are designed for ring and bus topologies.
The bypass relay also supports at-will activation of the bypass function for maintenance or selective shutdown of parts of the network. For example, when the wind gets too strong in a wind park, or when maintenance work is needed, one or more turbines can be easily taken out of the network without affecting the connections of the remainder.
The bypass relay is available with ports that support three different fiber types (multi-mode 62.5/125 µm, multi-mode 50/125 µm, single-mode 9/125 µm). The switching threshold is adjustable via a DIL switch over a range of 1V to 32V. In addition, a switch-on delay (adjustable for intervals of up to 75s) allows the switch's boot process to complete so that no data packets are lost or delayed when a switch comes back on line. The bypass relay also features an IP30 protection rating, an operating temperature range of -40°C to +70°C, and a redundant 24 VDC power supply. The 115 x 61 x 113 mm metal housing is DIN-rail mountable. LEDs on the front panel indicate the status of the device and network.
Belden
www.belden.com
- See more Control Engineering industrial network products.
