Oil filtration system
The gear and lube oil filtration system is designed for filtering high-viscosity fluids. The system features a 4-GPM flow capacity and handles a maximum viscosity of 10,000 SUS at 100 F. Its multi-stage filtration process ensures equipment receives clean oil. For added utility, the filtration system includes differential pressure gauges that indicate when each of the filtration elements need to...
The gear and lube oil filtration system is designed for filtering high-viscosity fluids. The system features a 4-GPM flow capacity and handles a maximum viscosity of 10,000 SUS at 100 F. Its multi-stage filtration process ensures equipment receives clean oil. For added utility, the filtration system includes differential pressure gauges that indicate when each of the filtration elements need to be changed. Two sampling ports are included for safely sampling and monitoring oil condition.
Trico Corp.
www.tricocorp.com
