Ohmic current sense resistors
The Model CSS series features low Temperature Coefficient of Resistance (TCR) for operating accuracy over wide temperature ranges and excellent long term stability.
The Model CSS series features low Temperature Coefficient of Resistance (TCR) for operating accuracy over wide temperature ranges and excellent long term stability. Their very low resistance levels, low thermal electromotive force (EMF) and high power handling capabilities make them ideal solutions for a variety of industrial applications and power electronics including battery management systems, switch mode power supplies and motor drives. The series supply resistance values as low as 0.5 milliohms, and customers can select from a range of low resistance options and power ratings of up to 9W.
Bourns
