No-mix epoxy resin system
This UV curable, no-mix epoxy resin system has exceptional sealing and gap-filling properties and excels in applications such as aligning parts and bonding irregularly shaped surfaces.
Master Bond UV10TK40 epoxy resin
Master Bond UV10TK40 is a UV curable, no-mix epoxy resin
system with exceptional sealing and gap-filling properties. It excels in
applications such as aligning parts and bonding irregularly shaped surfaces,
especially in production environments where increased speed and reduced waste
are paramount. Its very high surface hardness (Shore A >75) also makes it an
excellent choice for clear coating. The epoxy system is easy to apply and has a
viscosity of 35,000 - 45,000 cps. In addition to the standard packaging, the
epoxy is also available in convenient, ready-to-use syringe applicators. The
system contains no solvents or other volatiles and is 100% reactive. The epoxy is
not oxygen inhibited and cures rapidly in the presence of air upon exposure to
UV light at room temperatures. It forms highly durable bonds with a typical
tensile strength of 8,300 psi, a Young's modulus of 245,000 psi and an
elongation at break of 6%. Additionally, it has good dimensional stability and
high heat stability (94 C Tg).
Master Bond Inc.
