Differential pressure transducer monitors control pump differential pressures, chiller and boiler differential pressure drops and flow measurement of gasses and liquids. The model reduces inventory and installation costs by providing the user with field-selectable features, such as switch-selectable pressure ranges, selectable analog outputs and unidirectional and bidirectional ranging of span...
Staff
Differential pressure transducer monitors control pump differential pressures, chiller and boiler differential pressure drops and flow measurement of gasses and liquids. The model reduces inventory and installation costs by providing the user with field-selectable features, such as switch-selectable pressure ranges, selectable analog outputs and unidirectional and bidirectional ranging of span, all in one unit. An optional LCD display also is available for in-site reporting of range and output status. The transducer is offered in three versions, each with four unidirectional pressure ranges and four bidirectional pressure ranges. (Model 231 Multi-Sense by Setra Systems Inc.) www.setra.com Input #1 at www.csemag.com/QuickResponse
Connectors catalog highlights features and benefits of connectors, as well as specific technical information, product specifications, wire/tooling information, dimensions and temperature rise charts. Ordering information for each product includes part number, gender, available contact types, termination, wire and pin length and applicable tooling and accessory items. (Powerpole and Multipole Connectors by Anderson Power Products) www.andersonpower.com #2
Network graphic annunciator provides immediate emergency response information on a touchscreen display. The annunciator displays as many as 512 text messages and saves time by providing information on the source of alarms, along with applicable emergency contacts, hazardous material storage areas and more. The annunciator is mounted to the front of a fire alarm control panel or in multiple remote locations, and may be networked with the E3 Series expandable emergency evacuation system. (NGA by Gamewell-FCI) www.gamewell-fci.com #3
Parallelable UPS systems meet the power demands of semiconductor fabrication, process control, manufacturing systems and industrial infrastructures with a scalable platform and N+1 redundancy. The systems improve performance, capability and reliability through a faster processor that uses digital signal processing technology. (FN Series UPS Plus family by Falcon Electric Inc.) www.falconups.com #4
Light commercial diffusers are available in 2-cone, 3-cone and perforated models. The cone models feature a design that is adjustable to allow a sleek, flush look, or one that is pulled into extended position for maximum air flow. Both models are available with or without insulation. Collar design features a long 2.25 in. collar for flexduct connection, and slots for attachment of butterfly damper. The perforated model features a preformed insulation shell as standard. The perforated model also is available as a return grille configuration. (2x2 Light Commercial Diffusers by Metal-Fab) www.metal-fabinc.com #5
Vacuum interrupter monitor provides real-time monitoring of vacuum interrupters. If a loss of vacuum is detected, the model blocks operation of the switch, provides local indication and actuates a relay contact that is monitored locally or remotely. (VacStat by Joslyn Hi-Voltage) www.joslynhivoltage.com #6
Retrofit kit Power supply catalog lists more than 70 different models of DIN rail-mounted power supplies and accessories, such as modules for parallel and battery-charging applications. Included in this new catalog is the recently released panel mount IP65- rated power supply, which does not require mounting in an enclosure, and the new 100-amp, 24 Vdc DIN-rail mounted supply. The power supplies found in this catalog range from less than 1 amp to 100 amps; are single, dual and 3-phase; and offer output voltages ranging from 5 volts to 48 volts DC. (Power supply catalog by Automation Systems Interconnect Inc.) www.asi-ez.com #8
Desiccant dehumidifier reduces humidity levels and improves indoor air quality in commercial industrial construction applications. The system uses 30 amps of single-phase power and operates off a residential dryer outlet or range plug. It also can run from temporary power or electrical spider boxes that are used in construction sites. The dehumidifier processes air with 2.5-in. ESP and 80°F entering air and reactivation air with 2.5-in. and 110°F leaving air. (ProDry by Munters Moisture Control Services) www.munters.com #9
Card key switches
for hospitality facilities stop energy waste. The switches enable or disable power to electric circuits and loads inside a guestroom when the room is vacant. A common application is to collectively control all permanently installed luminaires and switched receptacles in a hotel guest room. When a hotel door entry card key is inserted in the HS-100/HS-150 card slot, the controlled circuits are energized. When the card key is removed, the controlled circuits remain energized for 30 seconds or more to allow safe egress. After this time delay, they will be de-energized. (Card key switches by Watt Stopper/Legrand) www.wattstopper.com #10
Fused glass pendants and wall sconces have been added to the manufacturer's lighting line. The wall sconces are suspended by nickel-finished powder-coated hardware. The glass pendants are 4 sq. in. and the fixtures heights range from 13.5 in. to 79.5 in. from the ceiling. (Fused glass pendants and wall sconces by Meyda Lighting) www.Meyda.com #11
Lighting is an alternative to traditional HID high-bay fixtures, and is available with either T5 or T8 lamp and ballast combinations. The lighting fixture is offered in either a wide or narrow width, its housing allowing for easy installation and maintenance, due to its tool-less reflector removal. (ILume Series by LSI Industries Inc.) www.lsi-industries.com #13
Flame detector features an improved design that offers a sealed electronic and sensor section to ensure protection from the environment during installation, and also additional field programmability features. The main section is sealed to protect the electronics and sensors from moisture during commissioning and maintenance, Modbus protocol is provided and a decrease of 50 mAmp of power is necessary. (Triple IR Flame Detector with SharpEye 20/20SI by Spectrex Inc.) www.spectrex-inc.com #14
Racks offer multi-angle door design and fully perforated front/rear doors from 22U to 47U and 600 mm to 800 mm widths. The racks hold 2,000 lbs. of static and dynamic load, due to its patented 7x2 roll frame. Improvements have been made from the previous version of this rack. These improvements include updated front door design, improved front and rear door handles and latches and three-section side panels. (HP 10000 G2 Series Rack family by Hewlett Packard) www.hp.com/go/infrastructure #15
ACULED lighting is offered standard in monochromatic—UV, blue, green, yellow, red or IR—as well as multi-color chips including an RGBY version. Under the ACULED VHL umbrella, the luminaires offer improved efficacy, easy-to-assemble design, long lifetime and improved thermal management. The thermal resistance of the ACULED VHL package is as low as 4.5 KW. (ACULED series by Perkin Elmer Optoelectronics) optoelectronics.perkinelmer.com #16
Motor management system delivers protection and controls automation, metering, communication and advanced diagnostics in a compact design. The system simultaneously communicates using Modbus—Serial or Ethernet—and either DeviceNet or Profibus DP protocols. This eliminates additional devices such as protocol converters and gateways. Continuous monitoring alerts operators to potential conditions that may lead to critical process interruption. This early detection ensures a targeted, proactive approach to maintenance and troubleshooting. (MM300 by GE Multilin) www.GEMultilin.com #17
Wind turbine grounding ring prevents bearing damage that may cause generator failure, unplanned downtime, costly repairs and lost revenue. The model is engineered to safely divert as many as 120 amps of continuous shaft current at frequencies as high as 13.5 MHz and charge as many as 3,000 volts. (AEGIS WTG by Electro Static Technology) www.est-aegis.com #18
Wireless I/O device meets a variety of requirements for SCADA systems and industrial process-control applications. The unit has analog, digital, totalizer inputs and relay outputs, and is designed for direct connection with process signal, requiring no interface components in most cases. The unit communicates through its RS485 data port for wired network or an integral spread-spectrum radio. (G303 RIO by G3 Technologies) www.g3ti.com #19
Lamps and ballasts are pulse-start designed to produce wide, full-spectrum lighting over indoor or outdoor areas. With a CRI of 90-plus, the product claims an efficacy of greater than 90% lumen maintenance and more than 20,000 hours of operating life. The lamps are available in wattages from 235 to 775 and meet NEC and ANSI requirements. (Uniform Natural White by Venture) www.venturelighting.com #20
Vacuum steam heat controller can control 12 zone valves. Modulate mode allows steam supply to respond to the building's unique demand. With reset mode, the control valve can be set based on the outdoor temperature, time of day and day of week. The outdoor reset schedule establishes the relationship between outside air and daytime and nighttime valve positions. (JC-VSH by Preferred) www.preferredinstruments.com #21
Classroom sinks combine vandal-resistant features with accessibility per ADA specs. Offered in two standard sizes, 17 in. x 25 in. and 19 in. x 31 in., the units are furnished complete with an 18-gauge stainless steel drop-in bowl, plus faucet, bubbler, drain system, cast brass P-trap, stop assembly and supply valve. Depths range from 4-1/2 in. to 6-1/2 in., and drain locations are per spec centered, rear centered, left or right rear, left or right center. (CRACF-ADA/CRAF-ADA by Just Manufacturing) www.justmfg.com #22
Indoor air quality filter is designed for use in high-occupancy commercial environments. The filter removes gases, such as nitric oxide, nitrogen dioxide and sulfer dioxide, ozone and VOCs. This filter also has been optimized to remove diesel and automobile exhaust and prevents contaminants from these sources from being introduced into the facility's HVAC system. (Purafilter—OA by Purafil Inc.) www.purafil.com #12
Retrofit kit ower head and cap tube that resists vibration. (Universal TR6 Thermostatic Expansion Valve kit by Danfoss) www.danfoss.com/north_america #7
