New Literature
Pumps and valves Complete guide to pumps and valves features a wide range of models. The 12-p brochure also offers typical applications, product options, and photos of each product.
09/01/2000
Pumps and valves
APV Americas - Fluid Handling
www.apv.com
Circle 316
Temperature monitoring
A 24-p catalog describes a line of products specifically designed to solve temperature measurement problems that can occur during the transportation, storage, and processing stages of temperature sensitive materials. Products include dataloggers, temperature recording labels, thermometers, and more.
Teletemp Corp.
www.telatemp.com
Circle 317
Dust collection
The Dust-Hog Supra Blast is available as either a single or a double configuration to remove dust, fumes, and other pollutants. An 8-p brochure shows how the unit works, lists features and benefits, and provides specifications for 22 models.
United Air Specialists, Inc.
www.uasinc.com
Circle 318
Retractable safety curtains
A 4-p brochure provides information about three retractable curtains designed for protection in safety and welding operations. The literature details each retractable's capabilities, dimensions, and features.
Frommelt Safety Products
www.frommeltsafety.com
Circle 319
Chiller systems
Brochure discusses the impact of ARI Standard 550/560-98 on multiple chiller systems. The brochure aids in clarifying integrated part load value and nonstandard part load value; and illustrates applications. Chiller load profiles, graphs, and tables are provided.
The Trane Co.
www.trane.com
Circle 320
Duct connectors
An 8-p brochure includes descriptions, illustrations, and photos of various connectors for round and oval ductwork systems. The literature offers a specification chart that lists each connector type.
McGill AirFlow Corp.
www.mcgillairflow.com
Circle 321
Chain hoists
Hand and electric chain hoists are the topic of a 24-p catalog. Photos, illustrations, construction features, and technical data are offered for each product.
Acco Chain & Lifting Products Div.
www.accolifting.com
Circle 322
Water jetting equipment
High-pressure and ultra-high-pressure water jetting equipment is featured in a new 6-p brochure. The brochure demonstrates how high-pressure water jetting can produce an extra-clean surface without the grit and dust of sandblasting.
NLB Corp.
www.nlbcorp.com
Circle 323
Dock loading
A 4-p brochure presents equipment for all dock loading needs. The literature features dock levelers, loading ramps, wheel risers, dock seals, machinery guards, and more.
T & S Equipment Co.
www.tesq.com
Circle 324
Vacuum lifters
Expanded catalog includes more than 50 photos of vacuum lifters, assembly workstations, and heavy-duty workstation systems. The vacuum lifters are available in either shop air or electric power versions and conform to OSHA and ASME standards.
CMCI/UNIVAC Div., The Caldwell Group, Inc.
www.caldwellinc.com
Circle 325
Ball bearing
Series 3000 heavy-duty ball bearing is featured in a new 12-p catalog. The bearing offers better lubrication, longer life, and higher speed than typical versions. Features, specifications, and applications are listed.
Rexnord Corp.
www.rexnord.com
Circle 326
Process control
An 8-p brochure describes Cimplicity OpenProcess software. The product provides all the tools needed to design, implement, document, and maintain a process control system using advanced control strategies and utilities typically associated with distributed control systems. A graphical representation shows the software's open architecture; a diagram shows a plant floor application of a typical system and components.
GE Fanuc Automation North America, Inc.
www.gefanuc.com
Circle 327
Compressed air dryers
A 4-p brochure describes how air dryers reduce dust collector maintenance and downtime by removing problem-causing moisture in compressed airlines. A variety of products are featured in the literature, including regenerative and single-tower desiccant dryers, refrigerated dryers, compressed air and gas filters, aftercoolers, and drain valves.
Van Air Systems
www.vanairsystems.com
Circle 328
Battery chargers
Catalog features 42 models of battery chargers, as well as accessories and related specialty wiring devices. The chargers are waterproof, shockproof, and tolerate heat and caustic chemicals and gases. The units offer a compact design, which is ideal for onboard charging of vehicles.
Guest Industrial
www.guestindustrial.com
Circle 329
Pipetools
Full line catalog contains products designed for plumbing, electrical, and general industrial applications. Each tool has a detailed product description and specifications.
Rothenberger USA, Inc.
www.rothenberger-usa.com
Circle 330
Humidity control
A 6-p brochure includes information on sensors, transmitters, controllers, displays, and humidistats that function in high-humidity environments and help eliminate conditions that contribute to poor indoor air quality. General product information, photos, and specifications are included.
Johnson Controls
Circle 331
Chemical process motors
Premium efficiency chemical process motors for IEEE STD 841 are the topic of a new flyer. The motors offer energy savings, cool operation, and long life.
Baldor Electric Co.
www.baldor.com
Circle 332
Safety posters
Get the word out around the plant that safety is your number one priority. A 32-p catalog contains posters on a wide range of safety topics, such as attitude, lifting and backs, tools, and much more. The 17 3 22-in. posters are a great visual safety reminder.
Bongarde Communications
www.safetysmart.com
Circle 333
Dust collection
Product selection guide includes application specifications for a complete line of dust collection and ventilation equipment that remove industrial process dusts.
Uni-Wash/Polaris Industrial Ventilation Group
www.unipol.com
Circle 334
Assembly tools
New catalog offers a wide range of products, including screwdrivers, angle nutrunners, impact wrenches, and more. Conversion tables for millimeter/decimal/fraction are included. Product photos and specifications are provided for each product.
Cooper Tools
www.cooperpowertools.com
Circle 335
Antivibration leveling casters and pads
A 6-p catalog describes antivibration leveling casters and leveling pads that provide a safe and easy way to move and level equipment, while eliminating the effects of vibration.
ORII Corp. of America
www.oriiusa.com
Circle 336
Wire carts and shelving
A new catalog describes round post wire carts and shelving systems. Photos and specifications are included.
Gillis Associated Industries
www.gillisindustries.com
Circle 337
Pipe insulation
Styrofoam brand pipe insulation and its uses are detailed in a new 16-p catalog. The brochure explains how the insulation offers a low life-cycle cost, long system life, and continuous plant operation due to fewer insulation failures. Easy-to-read graphs compare this product with other mechanical insulation products, including cellular glass, elastomeric rubber, glass fiber, and mineral wool.
The Dow Chemical Co.
www.dowpipe.com
Circle 338
Roof exhaust fans
New catalog provides information for Models G and GB centrifugal rooftop fans. The fans offer nominal wheel diameters of 6-54 in., and are available in more than 45 configurations.
Greenheck
www.greenheck.com
Circle 339
Flow measurement
Brochure features electronic instruments for automated and computer-controlled flow measurement systems, turbine flowmeters, weight-time flowmeter calibrators, preamplifiers, rate totalizers, and batch controllers.
Cox Instrument
www.cox-instrument.com
Circle 340
Pneumatic cylinders
A 20-p catalog features a line of NFPA pneumatic cylinders with and without an integral rod-locking device. The publication contains design details, mounting dimensions, technical data, and more. Information is presented for the CA series of cylinders, available in bore sizes 11/2-12 in. with standard hard chrome and polished rods for use with up to 250-psi air or oil.
Advanced Machine & Engineering Co.
www.ame.com
Circle 341
Enclosures
The 2000-2001 specifier's guide details electrical/electronic enclosures. The publication includes technical information and standards.
Hoffman
www.hoffmanonline.com
Circle 342
Hydraulic dock levelers
The HD-1700 STL leveler can be configured to meet the demands of virtually any loading dock operation. A 6-p brochure describes how the product prevents drop-off accidents, provides free-fall protection, and reduces service and maintenance.
Rite-Hite Corp.
www.ritehite.com
Circle 343
HVAC instrumentation
A full line of digital, electronic instruments for HVAC/R and related industries is featured in an 8-p brochure. Products include IR thermometers, humidity measurement tools, and more.
Testo, Inc.
www.testo.com
Circle 344
MSDS management
Literature describes MSDSpro software designed to streamline the process of material safety data sheet (MSDS) management. More than 240,000 standardized MSDS documents are included on the CD-ROM-based program. Software keeps MSDS records current with free updates via the internet.
Aurora Data Systems, Inc.
www.msdspro.com
Circle 345
