Natural gas leak repair kit
The Trident-Seal live natural gas repair kit seals active leaks up to 60 psi. It’s suitable for repairing joint leaks, manifold leaks, pinhole leaks, online repairs and live gas leaks. The system’s operating service temperature is -50 to 250 F; application temperature is 0 to 150 F. The kit works with pipes ranging from 1/2 to 21/2 inches in diameter and roll sizes of 2 by 5.
By Plant Engineering Staff November 15, 2007
The Trident-Seal live natural gas repair kit seals active leaks up to 60 psi. It’s suitable for repairing joint leaks, manifold leaks, pinhole leaks, online repairs and live gas leaks. The system’s operating service temperature is -50 to 250 F; application temperature is 0 to 150 F. The kit works with pipes ranging from 1/2 to 21/2 inches in diameter and roll sizes of 2 by 5.8 inches, 3 by 10.4 inches and 4 by 17.3 inches.
Neptune Research Inc. : www.neptuneresearch.com
