Nanocleaning sulfur from fuel
Mats of metal oxide nanofibers that can scrub sulfur from petroleum-based fuels much more effectively than traditional materials are now under development.
ISS SourceMats of metal oxide nanofibers that can scrub sulfur from petroleum-based fuels much more effectively than traditional materials are now under development.
That kind of efficiency could lower costs and improve performance for fuel-based catalysis, advanced energy applications and toxic gas removal.
Co-led by Mark Shannon, a professor of mechanical science and engineering at the University of Illinois until his death this fall, and chemistry professor Prashant Jain, the researchers demonstrated their material in the journal Nature Nanotechnology.
Sulfur compounds in fuels cause problems on two fronts: They release toxic gases during combustion, and they damage metals and catalysts in engines and fuel cells. They usually end up removed using a liquid treatment that adsorbs the sulfur from the fuel, but the process is cumbersome and requires the fuel be cooled and reheated, making the fuel less energy efficient, the researchers said.
To solve these problems, researchers turned to solid metal oxide adsorbents, but those have their own sets of challenges. While they work at high temperatures, eliminating the need to cool and re-heat the fuel, their performance has stability issues. They lose their activity after only a few cycles of use.
Previous studies found sulfur adsorption works best at the surface of solid metal oxides, graduate student Mayank Behl, from Jain’s group, and Junghoon Yeom, then a postdoctoral researcher in Shannon’s group, set out to create a material with maximum surface area. The solution: Tiny grains of zinc titanate spun into nanofibers, uniting high surface area, high reactivity and structural integrity in a high-performance sulfur adsorbent.
The nanofiber material is more reactive than the same material in bulk form, enabling complete sulfur removal with less material, allowing for a smaller reactor. The material stays stable and active after several cycles. Furthermore, the fibrous structure grants the material immunity from the problem of sintering, or clumping, that plagues other nano-structured catalysts.
“Our nanostructured fibers do not sinter,” Jain said. “The fibrous structure accommodates any thermophysical changes without resulting in any degradation of the material. In fact, under operating conditions, nanobranches grow from the parent fibers, enhancing the surface area during operation.”
Jain’s group will continue to investigate the enhanced properties of nanofiber structures, hoping to gain an atomic-level understanding of what makes the material so effective.
“We are interested in finding out the atomic sites on the surface of the material where the hydrogen sulfide adsorbs,” said Jain, who also works with the Beckman Institute for Advanced Science and Technology at the University of Illinois. “If we can know the identity of these sites, we could engineer an even more efficient adsorbent material. The atomic or nanoscale insight we gain from this material system could be useful to design other catalysts in renewable energy and toxic gas removal applications.”
