Multivariable flowmeter
The OPTISWIRL 4070 C flowmeter is a multivariable instrument that combines a vortex flow sensor with built-in temperature compensation and optionally available integrated pressure in a two-wire configuration. The flowmeter measures standard volumetric and mass flow of conductive and non-conductive liquids, gases and vapors – even in applications that are prone to pressure and temperature ...
The OPTISWIRL 4070 C flowmeter is a multivariable instrument that combines a vortex flow sensor with built-in temperature compensation and optionally available integrated pressure in a two-wire configuration. The flowmeter measures standard volumetric and mass flow of conductive and non-conductive liquids, gases and vapors — even in applications that are prone to pressure and temperature fluctuations. It features a non-wearing, fully welded, stainless-steel structure that is resistant to corrosion, high pressures and temperatures. It also features an Intelligent Signal Processing System that facilitates stable flow readings while eliminating noise and spurious frequencies in the process.
Krohne
www.krohne.com/northamerica
