Multifunction protective relay reduces wiring
Siprotec 4 family of multifunction protection and automation products operates as protection relays, RTUs, programmable logic controllers, meters, equipment monitors, local annunciator/controllers, and fault record- ers.
Siprotec 4 family of multifunction protection and automation products operates as protection relays, RTUs, programmable logic controllers, meters, equipment monitors, local annunciator/controllers, and fault record- ers. Designed for medium and high-voltage applications, the devices replace the maze of wire traditionally required for substation control and protection.
Siemens Power Transmission & Distribution; www.siemenstd.com
TO VOTE, WRITE 116 ON BALLOT
For more information, circle 5 on card
