Multi-sense humidity probe
The HP125 Multi-Sense Humidity Probe measures relative humidity, dew point, temperature, and pressure in industrial and laboratory applications.
By Edgetech Instruments, Inc. May 20, 2016
The HP125 Multi-Sense Humidity Probe measures relative humidity, dew point, temperature, and pressure in industrial and laboratory applications. It continuously measures up to 4 measurement parameters using a single intelligent sensor tip, including RH%, calculated dew point, temperature and either absolute or barometric pressure. Users can choose the measurements needed for their application and budget. The HP125 probe provides 0-10 VDC analog outputs plus an RS-232 serial interface for reporting functions. The HP125 may be used in the simplest configuration for ambient air monitoring or it can be mounted remotely for direct insertion into glove boxes, HVAC ducts, environmental test chambers, circulation pipes, refrigerated storage rooms, engine test filter rooms, and many other manufacturing environments.
www.edgetechninstruments.com
