Multi-channel controllers for data acquisition and data logging
The Zen RTU and the Zen Datalogger are ideal in a range or heavyweight industrial monitoring and control applications.
By Define Instruments July 18, 2016
The Zen RTU and the Zen Datalogger are ideal in a range or heavyweight industrial monitoring and control applications. The Zen RTU is ideal for applications which require collation of multiple signals routed directly to a master console such as for connecting directly to a PLC and SCADA system. It has four digital inputs and a RS485 Modbus/RTU port. The Zen Datalogger is appropriate for applications that require acquisition and visualization of data from multiple sources. It has 2 analog outputs and 2 relay contact outputs for control and alarm applications.
Define Instruments
www.defineinstruments.com
