Mounting ring uses 2-12 luminaires
Highmast Lighting System uses a mounting ring that allows 2-12 area lighting luminaires to be operated at heights up to 150 ft. The outdoor system requires fewer poles and allows the luminaires to be lowered to the ground for maintenance.
Highmast Lighting System uses a mounting ring that allows 2-12 area lighting luminaires to be operated at heights up to 150 ft. The outdoor system requires fewer poles and allows the luminaires to be lowered to the ground for maintenance. JJI Lighting Group, Quality Lighting Div.
