Mounted ball bearings
Emerson's Sealmaster introduces material handling mounted ball bearings.
March 8, 2013
Emerson’s Sealmaster material handling mounted ball bearings feature cast iron housings and an extended inner race insert bearing with ball riding nylon retainer. The insert features a rivet to prevent outer ring rotation and is available with setscrew or SKWEZLOC concentric locking collar and optional snap-on end cap. The contact seal provides balance between contaminant resistance, grease loss, and friction. The bearings are available in common unit material handling industry bore sizes and housing configurations.
Sealmaster
www.emerson-ept.com
