Motorized blower for industrial, commercial applications
The TCC motorized blower is an air-moving package that is designed for applications that require low noise and high efficiency.
The TCC motorized blower is an air-moving package that is designed for industrial and commercial applications that require low noise and high efficiency and have limited space. This compact fan is speed controllable. It combines a flange-mounted scroll housing with an efficient motorized impellers for air performance and sound levels. The rugged steel housing has a corrosion resistant epoxy coating to provide maintenance free operation. Other features include a speed controllable external rotor motor, flanged and drilled outlet, and epoxy-coated steel housing. It is also available in single- or three-phase voltages.
Continental Fan
