Molded-case circuit breakers
Rockwell's Allen-Bradley Bulletin 140G molded-case circuit breaker family protect against overload, short circuit, and ground-fault conditions and enable quicker clearing of higher-level faults at higher voltage.
02/12/2014
Rockwell's Allen-Bradley Bulletin 140G molded-case circuit breaker family protect against overload, short circuit, and ground-fault conditions and enable quicker clearing of higher-level faults at higher voltage. Courtesy: Rockwell AutomationThe Allen-Bradley Bulletin 140G molded-case circuit breaker family from Rockwell Automation are designed to protect against overload, short circuit, and ground-fault conditions. Eight frame sizes span a current range of 15 to 3,000 A and voltage range of 200 to 690V. All frame sizes are available in three- and four-pole versions. The line features increased short-circuit protection with coordination available for motors from 0.1 to 630 kW, fault currents up to 150 kA, and operational voltages up to 690V. The Bulletin 140G circuit breakers enable quicker clearing of higher-level faults at higher voltage. The modular design adds installation flexibility with a full range of operators, from motor and rotary to flange operators. The interrupting capacity from 25-150 kA allows a single unit to address multiple applications, which helps reduce product stocking. The extended line of flexible accessories includes auxiliary and trip-unit alarm contacts, wiring terminations, and electronic trip units from 20-3,000 A, allowing the product to meet the requirements of applications on a global basis.
The Allen-Bradley family of miniature circuit breakers provides branch-circuit, supplemental and ground-leakage protection. This expanded portfolio for control circuit and load protection is IP20 finger safe, offers a wide array of available accessories, and features a versatile dual-cage terminal design. The Allen Bradley Bulletin 1489-M and Bulletin 1492-SPM circuit breakers are rated up to 63 A. The Bulletin 1489-M miniature circuit breaker provides branch-circuit protection with current limiting and is suitable for extreme conditions. The Bulletin 1492-SPM miniature circuit breaker protects equipment, systems and cables by quick disconnection. The Bulletin 1492-RCDA miniature circuit breaker detects and interrupts earth leakage for equipment protection.
In addition, when considering the circuit protection needed for applications, machine builders can more easily determine the necessary circuit protection for applications with easy-to-use selection and ordering tools. The Global Short Circuit Current Ratings (SCCR) Selection Tool provides coordinated high-fault, branch-circuit solutions for motor starters, soft starters and component drives. The tool generates letters of compliance for approved product combinations. A variety of selection guides and technical documentations are also available to machine builders online.
Rockwell Automation
www.rockwellautomation.com
- See more Control Engineering energy and power products.
