Modules for harsh, corrosive industrial environments
The CLXT Modules are available in three versions for Ethernet, Serial Communications, and Profibus Master/Slave applications
December 4, 2013
The CLXT Modules are designed for use with Rockwell ControlLogix XT PLCs in harsh and corrosive industrial environments. The CLXT Modules are available in three versions: the SST-ESR2-CLXT Module for Ethernet and Serial Connections, the SST-ER4-CLXT Serial Communication Module with four Modbus serial ports and the SST-PB3-CLXT-RLL for Profibus Master/Slave applications. All versions feature wider temperature ranges, conformal-coated boards and harsh-duty components.
Molex
www.molex.com
