Modular quick-connect system
The BradPower quick-connect system is designed for the food, beverage and pharmaceutical industries; meets FDA-regulated sanitary requirements; and complies with the NFPA-79-2002 standard, which paved the way for conduit-free, soft-wired systems for industrial machinery. The modular wiring system features rugged, factory-applied connector heads molded onto cables in a system that includes trunk...
The BradPower quick-connect system is designed for the food, beverage and pharmaceutical industries; meets FDA-regulated sanitary requirements; and complies with the NFPA-79-2002 standard, which paved the way for conduit-free, soft-wired systems for industrial machinery. The modular wiring system features rugged, factory-applied connector heads molded onto cables in a system that includes trunk/feeder cordsets; drop/branch cordsets; tees and reducing adapters; receptacles; a power distribution box; and disconnect switches and accessories. Smooth overmolds eliminate food traps.
Woodhead Industries , div. of Molex : www.woodhead.com
