Mix spray nozzles
External atomizing mix spray nozzles atomize fluids in situations where a high volume of liquid is needed and can be used with a viscosity up to 800 cp
External atomizing mix spray nozzles atomize fluids in a range of spray patterns and are designed for situations where a high volume of liquid is needed. They can be used on liquids with a viscosity up to 800 cp. The external mix nozzles are available in a round or flat pattern. They combine liquid and compressed air to create a coating of liquid that can be easily adjusted to meet the needs of your application. The external mix atomizing nozzles allow the user to coat, cool, treat, and paint a variety of products. Used with water, atomizing nozzles are an efficient way to evenly cool hot items in an automated process.
Exair
