Material Handling Systems
By Plant Engineering Staff
Tow tractors
The AC electric tow tractors, available with 3,300 and 4,000-pound drawbar pull capacities, feature an ac drive system and controller area network communication technology. MOSFET controller technology provides acceleration, top travel speed and smooth speed control. A power-keep function helps maintain battery charge. The tractors use three forms of regeneration to maintain battery performance: an accelerator release system, a shift directional lever and a brake pedal depression system.
Toyota Material Handling, USA, Inc. : www.toyotaforklift.com
Transforming cart
The Trans4mer cart is a four-wheel cart that transforms from a hand-operated pushcart to a towing cart. Users can transform the unit from a push cart to a towing cart by tipping the tow bar down. The cart returns to push cart mode by lifting the tow bar up. When the bar is up, the lead casters lock in place and the rear caster swivel to accommodate hand operation. With the tow bar is down, all the wheels swivel for towing.
Topper Industrial : www.topperindustrial.com
Pail lid
The PIG 5-gallon latching pail lid provides access and security to materials stored in 5-gallon, open-head, steel drums. Designed for applications where the contents of the drum need to be accessible, the unit eliminates the need to replace lids, rings or bolts after each use. It fits on pails with an 11
New Pig Corp. : www.newpig.com
Lift truck
The 8-series AC reach lift truck is designed for distribution centers, retail operations, refrigerated warehouses and third-party logistics applications. It’s available in three models, with lift capacities of up to 4,500 pounds, depending on the model. The truck features ac-powered drive and hydraulic systems and an electric disc brake. It contains no motor commutator, brushes or springs. The truck is available with three masts to accommodate heights of more than 30 feet.
Cart
Designed to carry two “daughter” carts and deliver items without uncoupling a train of carts, the hydraulic mother cart is pulled by a tugger and is equipped with a hydraulic system that can lift other carts off of the floor for transport. The hydraulic system receives power from the battery of the tugger.
Metal recovery system
The FinesSort metals recovery system is equipped with magnetic components to recover ferrous and non-ferrous metals from fines waste stream in scrap yards. Available in 24-, 48- and 60-inch versions, the machine is built from heavy-gauge steel and is assembled on a steel framework. It recovers metals that are less than 1 inch in diameter.
Eriez : www.eriez.com
Fleet management system
The iWarehouse enterprise fleet management system draws real-time information from the operating systems of lift trucks. It allows users to access the information from a Web portal and can generate reports and benchmark truck and operator productivity. The system diagnoses potential lift truck issues remotely. It can be set to limit lift speed and acceleration and alert managers of maintenance issues or impacts, among other traits.
The Raymond Corp. : www.raymondcorp.com
Conveyor cart
The engine block conveyor cart features a roller conveyor deck that transfers engine blocks to an assembly line. The engine block is pushed off the roller conveyor by an electric worm gear. Powered by the battery of the tugger, the cart can carry engine blocks of various weights. It can accommodate up to four engine blocks at a time.
Lift truck checklist
Available for propane and electric counterbalance lift trucks and electric narrow aisle and pallet trucks, the lift truck log contains more than 600 daily checklist forms. Other forms include 24 repair request forms, four accident report forms and four near-miss report forms. A lock-out tag is included for use if the truck becomes unsafe, and a preventive maintenance history can be used to track service. All components reside in a plastic case that attaches to the truck.
Liftow Ltd. : www.liftow.com
Electric hoist
The NER/ER three-phase electric hoist features smart brake technology and dual-speed via an under-the-cover variable-frequency drive. Available in two- and three-step infinitely variable control, the UL-listed hoist has a capacity range from 1/8 to 20 tons. Moter, brake and inverter components are engineered to accommodate low-noise operation. Other features include a nickel-plated load chain, five or six pocket-load sheaves, count hour meters, and low-headroom upper and lower limit switches.
Harrington Hoists Inc. : www.harringtonhoists.com
Vacuum pumps
The HeliFlow industrial series positive displacement blowers and vacuum pumps use helical, tri-lobe rotors to lower pulsations to protect downstream instrumentation. Designed for reduced noise levels, the blower is engineered to withstand overhung loads with a limit of 13,500 inch-pounds. The pumps deliver pressure to 15 psig, vacuum to 16-inch Hg and airflow to 3,200 cfm.
Gardner Denver, Inc. : www.gardnerdenverproducts.com
Cart
The Corral cart with self-elevating dollies delivers multiple dollies to a work cell without the need to uncouple carts from a train or use of a fork truck. Powered by a set of springs, the dollies automatically raise and lower when items are loaded or unloaded. Designed to carry small totes or boxes, the springs in the cart keep loads at an ergonomic height for the operator. The spring-loaded shelves can be changed to accommodate different weight requirements.
