Maraging steel electrodes
The maraging steel electrodes have high toughness levels at maximum tensile strength which are also much appreciated in the Tool & Die manufacturing industry.
The two maraging steel electrodes, EutecTrode XHD 6860 and 6855XHD have high toughness levels at maximum tensile strength which are also much appreciated in the Tool & Die manufacturing industry.The electrode feature smooth, regular weld surface requiring minimal machining, low temperature aging treatment which eliminates quenching defects and distortion, retention of aged hardness up to higher service temperatures, as well as good weldability without preheating for practical engineering applications. The XHD 6860 protective weld coating solutions are recommended for parts particularly the tool & die manufacture sectors, automotive press, and plastic injection moulding industries.
Castolin Eutectic
