Making a better seal
Plantwide Sealing Program (PSP) helps boost overall reliability, reduce costs, extend sealing efficiencies, and increase bottom line results.
Plantwide Sealing Program (PSP) helps boost overall reliability, reduce costs, extend sealing efficiencies, and increase bottom line results. PSP is a process that involves a plant survey, establishing a database, seal and equipment analysis, cost reduction analysis, team training, and decision making. The object is to reduce seal inventory.
Flex-A-Seal
Circle 268
