Maintenance Tips & Tricks – 2000 – #20
Stopping gas Problem: Most floor drains not actively used tend to dry out. Sewer gases can escape when this occurs. Can the gases be stopped from escaping? Solution: Pour 1/4 cup of cooking oil in the floor drain. The oil floats to the top of the water and prevents it from evaporating. Contributor: Paul Salvo, Eaton Corp. TCC, East Lake, OH List of Tips & Tricks |
Plant Engineering |
