Maintenance Tips & Tricks – 1999 – #4
Bridle the bristles
Problem: Cleaning parts in the parts washer is aggravating because the bristles on the standard round brush are standing out in all directions.
Solution: Borrow a trick from painters — “bridle” the brush. Take an o-ring a little smaller than the brush diameter and roll it down the bristles to get the desired shape.
Contributor : Philip J. Soliday, Freeman Products, Knox, IN; 219-772-2129
List of Tips & Tricks
Plant Engineering
