Magnetic cylinder sensors
Magnetic T- and C-slot cylinder sensors that provide discrete output regarding the end-of-stroke position of pistons in pneumatic cylinders are suitable for automated equipment applications where piston position must be closely monitored.
By Plant Engineering Staff
Magnetic T- and C-slot cylinder sensors that provide discrete output regarding the end-of-stroke position of pistons in pneumatic cylinders are suitable for automated equipment applications where piston position must be closely monitored. The compact noncontact sensors offer precise, repeatable switching behavior with defined and tested activation sensitivity. Their IP67-rated plastic housing provides protection in harsh and wet environments. Available in both NPN and PNP outputs, the sensors feature cable or fly-lead connectors and a, 3- to 30-V supply range.
Baumer Ltd.
www.baumerelectric.com
