Low-resolution analog modules
Productivity2000 programmable controllers are low-resolution analog modules are designed for cost-conscious applications.
Productivity2000 programmable controller line include 12 and 13-bit resolution current and voltage analog input and output modules for cost-conscious applications. The modules have eight or sixteen channels for receiving 0 to 20 mA signals, eight or sixteen channel voltage analog input modules for receiving 0 to 10 Vdc signals, and current analog output modules with eight or sixteen channels of 4 to 20 mA outputs. A dual-voltage power supply is featured to provide isolated power to the Productivity2000 base from an external 24 Vac or 12-24 Vdc source. No power budgeting is required, so any combination of I/O modules may be installed in any slots.
AutomationDirect
www.automationdirect.com
