Long-range wireless transmitters for process measurements
Omega Engineering UWXL Series industrial wireless transmitters offer flexibility for process measurement applications. Capable of ranges to 450 m (1,500 ft) line of sight (LOS), the UWXL transmitters are designed for a variety of applications, including temperature, infrared temperature, relative humidity, process transducers with standard voltage or current outputs, flow (pulsed frequency), and pH.
Omega Engineering UWXL Series industrial wireless transmitters offer flexibility for process measurement applications. Capable of ranges to 450 m (1,500 ft) line of sight (LOS), the UWXL transmitters are designed for a variety of applications, including temperature, infrared temperature, relative humidity, process transducers with standard voltage or current outputs, flow (pulsed frequency), and pH. Thermocouple models are user configurable for nine calibrations; RTD units are compatible with 0.00385 and 0.00392 curve Pt100 sensors. The transmitters can transmit data at intervals configurable from once every 2 seconds to every 2 minutes. Transmitted data includes the process measurement, ambient temperature, RF signal strength, and battery condition. Software provided can display information in real time, allowing PC use as a multi-channel meter, recorder or data logger; data can also be exported to a standard spreadsheet file. UWXL transmitters are compatible with a wide variety of Omega wireless receivers.
Omega Engineering
Also see:
Control Engineering new product area for Process Instrumentation
Omega Engineering DIN rail thermocouple terminal blocks have audit capable female connector
Dual voltage SCR dc motor speed control, up to 2 hp motors
